head swap
Old 05-04-2009, 10:30 AM
bundlosticks
bundlosticks's Avatar
Question head swap
i just recently swaped the heads in my 89 mustang 5.0 i got the whole motor put together in starts right up but dies immediately.
any ideas of what i did wrong?
bundlosticks is offline
Old 05-04-2009, 10:45 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
vac leak, dizzy stabbed incorrectly possibly. those are most common after a head swap.
FivePointOhh is offline
Old 05-04-2009, 10:48 AM
jthorn9
The Godfather
jthorn9's Avatar
Did you play with the TB settings at all, that will cause the problem.
Other things to look into would be make sure that the EGR return tube isn't leaking out the butt, that will cause a horrible idel problem, not sure about dieing, but worth looking into.
Intake gasket leak could also cause a problem.
Did you rehook up everything around the distributer and coil?
Check to make sure all your spark plug wires are on the spark plugs.
jthorn9 is offline
Old 05-04-2009, 10:57 AM
bundlosticks
there is not a special way you torque the rocker arms?
Old 05-04-2009, 10:58 AM
bundlosticks
and what is the tb settings?
Old 05-04-2009, 12:51 PM
FivePointOhh
in limbo
rocker arms...if stock stamped ones, they are just tq'd on at 20lbs and they are good. there really is no adjustment for them.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: head swap
