codes 41 and 91 on 93 lx 5.0
Old 05-04-2009, 04:22 PM
toms93lx
toms93lx's Avatar
Exclamation codes 41 and 91 on 93 lx 5.0
had a machanic tell me it could be my mass air flow couseing it.
how can i check it
toms93lx is offline
Old 05-04-2009, 04:24 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
its not a vacuum leak?
TrimDrip is offline
Old 05-04-2009, 04:33 PM
toms93lx
toms93lx's Avatar
no not a vacume leak. atleast cant find one. i was told when it ends up being both banks of o2 sensors that it is normally the mass air flow
toms93lx is offline
Old 05-04-2009, 04:53 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I have a 93 lx that I am taking the meter off maybe this week, if I can get an appoitment. I am upgrading to 42 lb. injectors. It is a reman and not that old. If you want it?
TrimDrip is offline
Old 05-04-2009, 05:14 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it
could be but you also need to consider checking fuel pressure/possible weak pump, check it at idle and under load and check for restricion in a fuel filter as both these will cause lean conditions....clean maf with maf cleaner
mjr46 is offline
Old 05-04-2009, 08:31 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Originally Posted by mjr46
it
mjr46 is right. The fuel pumps in those cars put out a lot of psi. They will keep a car running when a chevy pump won't. When I bought my car and took the fuel pump out of it, the fuel couldn't even pour out of the outlet. We turned it upside down and filled a 20oz. mt.dew bottle up to the label with fuel that could be thrown on a campfire and wouldn't burn.
TrimDrip is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: codes 41 and 91 on 93 lx 5.0
