rebuild to a 347 stocker from a 302
i have a 85 mercury capri with a 302 roller block the block is from a 87 mustang. i am rebuilding this motor i need help with what parts or stocker kit would work best, and other cams and heads to use with this motor. i want to get a comp cam with a 347 stocker kit, with gt40 heads i just want to get other suggestens from others what should i do????????????????
go with a 331 kit. you wont have to notch the block.the arm ratio is better to. less stress on the cylinder walls.
http://www.jegs.com/i/Scat/942/1-94055BE/10002/-1
here you go
here you go
you really need to read this:^^^^^^^^^^^^^^^http://sbftech.com/index.php/topic,6087.0.html
there are sbc's out here with far worse rod ratio's than a 347 and they have survived well over 100k.......what you state is myth
i think its more of a rod bolt issue. not the rod. dont get me wrong ive never dont it . but i do have a stack of magazines 6 foot tall. and i read about them alot. i was gonna build one after this 302 bit it.
