CAR DIED WONT START!!! HELP ASAP
I was having a spuddering issue over the past few days and now driving home the car just died, I was close enough to home to coast into my driveway. The car cranks over and but just wont start. It has no spark, what would the most common problem be. I need to get this thing running by the end of the night!!
Jay
Jay
Before you go spending money, you need to verify your problem. If at all possible run codes. You said you just installed your GT-40 intake. My bet is, you have a bad Hall Effects Sensor in the dizzy, since you took it out and messed with it a bit. You could also have a bad TFI module. You can take that off and take it to autozone where they can test it.
Yes, the hall effects sensor would prevent the car from getting any spark. It is also known as the Profile Ignition Pick-up (PIP). SImply stated,the Hall-Effect sensor signals the Thick Film Ignition (TFI) module, which is then relayed to the ECA. This happened to a guy a while back, his car would not start. He rebuilt the dizzy/ with the new HES, and the car started right up and ran great. In order to get to it, you have to dismantle the dizzy. In many cases, it's better to just replace it(It's what I personally did). I personally believe it is either the TFI or HES. Test the TFI out first. If it fails, then that is obviously your problem.
could be rotor, stator, tfi, coil ect ect
http://sbftech.com/index.php/topic,588.0.html
