Electrical Problem Plz help
i have a 84 mustang. 5.0 w/302. pretty much all stock. i replaced the alternator because it went out then i replaced the external voltage regulator and the solenoid. my battery is not getting charged. and the car wont stay on if i disconnect the positive terminal(once the car is on).
i took it to a general mechanic and he said i need to take it to an electrician.
anyone have any ideas?
what kinda mechanic did you take it to?? a lube a dube dube place with no ability to diagnosis stuff?? anyway , you'll need a wiring diagram of the charging system and you'll need to trace the charge wire and make sure it's not cut anywhere and all the fusible links are good
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
