I have a random miss
Old 05-07-2009, 02:52 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Default I have a random miss
Alright since I have had my car there has been a random miss. It is not constant it has no rhythm to it or anything. It is very noticeable at idle because the car and shifter shakes and you can hear the dead note in the exhaust. If I go WOT I don't really notice it but I'm sure it is still there.
I have replaced the plugs, wires, cap and rotor so far. I was thinking it could be the coil maybe? Anyone have an idea? Thanks
ryan_89_mustang is offline
Old 05-07-2009, 02:59 PM
kennebell92conv
kennebell92conv's Avatar
koeo test and koer test to see if has codes
kennebell92conv is offline
Old 05-07-2009, 03:03 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
go ahead and run the engine balance test too.
TrimDrip is offline
ryan_89_mustang
Yeah i ran it and I'm getting nothing except for my egr and emissions junk which it not functional so nothing.
Old 05-07-2009, 03:04 PM
ryan_89_mustang
I did that as well and i get different cylinders every time.
Old 05-07-2009, 03:17 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
when the last time you put o2 sensors in?
TrimDrip is offline
Old 05-07-2009, 03:20 PM
ryan_89_mustang
I haven't but it has a miss in open loop too. It doesn't seem quite as bad until it warms up to operating temperature though.
Old 05-07-2009, 03:37 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
you never had trouble with it not wanting to start?
TrimDrip is offline
Old 05-07-2009, 03:45 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
a guy that works with my mechanic has a chevy truck (bare with me) that is having the same problem. They put the tester on it and it shows multi-cylinder missfire. He has tried plugs, wires, two distributors, coil, ignition, computer, crank sensor, fuel filter, fuel pump, fuel pump relay, new injectors. The fuel pressure is in spec.
He is now wondering about the 02 sensors.
His truck won't even crank sometimes in the morning until he bumps the fuel pump relay. Hell, the thing may have corroded wiring for all I know.
TrimDrip is offline
Old 05-07-2009, 03:54 PM
ryan_89_mustang
Starts perfect when cold. When hot when you start it, it will start then surge low and die really quick then start it again right after it dies and it will start and idle fine.
Quick Reply: I have a random miss
