What Kind? How Much? & Advice!? Please
Hey guys i just got my 1988 5.0L 5 Speed.
I checked the oil and im very low and its pretty dark. The oil and gas gauges arent working for some reason?
Im gonan change the oil and filter tomorrow.
How Much Oil Do I Put In? And What Type?
Anyone have an idea why my gauges arnt working?
( Sorry i used the search option and couldnt find an answer. 5 qaurts of oil? from totally empty with filter changed? and make sure i drain both oil plugs? )
any tips please.
any tips please.
5 quarts of oil.. 10w-30 is what i run in mine and is what most people use. If you have leaks underneath then go alittle heavier. If youre under the car changing the filter.. dont get directly underneath it or else youll get rained on by oil(from experience)
ok thanks alot guys i dont know much tbh ill admit im a newb to this. im only 18.
The gauges got me worried. if it is bad senders will it be difficult to replace my self and how expensive are they?
go to autozone and ask the guy behind the counter, also buy a repair manual from their
as for the oil
Motorcraft FL-1A
10w30 or 10w40(I use SuperTech since 5.0s commonly burn a quart every 1,000 miles)
as for the oil
Motorcraft FL-1A
