more problems!!
Old 05-08-2009, 04:30 PM
topless91gt
topless91gt's Avatar
Default more problems!!
Here's a good one for the pros!! The idle will start at 800 then rise to over 2,000 then drop a little and go back to 2000. Its not like your usual idle surge! When cruising with my foot lightly on the gas it bucks like crazy.When I accelerate a little is smooths out.
This is am intermitten problem. It may act up for 50-100 miles then do fine for 30 or so. Doesnt matter if the engine is cold or warm. I pulled the following codes!
51
81
82
84 ( blocked off EGR so I understand this one)
63
Thanks guys!!
topless91gt is offline
Old 05-08-2009, 09:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
i'M LAZY...what are the code definitions for those codes
mjr46 is offline
Old 05-09-2009, 01:52 AM
topless91gt
LOL. Yeah I guess that would help.
51. ECT/ACT reads -40F or open circuit
81. (Chilton manual had this one listed twice) IAS circuit failure, Air Management 2 circuit failure
82. Air management 1 circuit failure
84. EGR Vac. Solenoid failure
63. TP circuit below minimum voltage. ( This was in continuous memory)
Old 05-10-2009, 01:11 AM
topless91gt
bump.
Old 05-10-2009, 08:42 AM
mjr46
mjr46's Avatar
do you still have smog and egr stuff on the car??
mjr46 is offline
Old 05-10-2009, 11:43 PM
topless91gt
smog pump is still on the car but its disconnected. all EGR stuff is gone and block off plate installed.
Old 05-10-2009, 11:53 PM
AdderMk2
Banned
AdderMk2's Avatar
ECT... test the circuit and the sensor.. my probe did the same crap when the ECT was bad
AdderMk2 is offline
Old 05-14-2009, 10:38 PM
topless91gt
Thumbs up
Thanks Adder. Looks like you were right on the money. Replaced ECT and ACT. Check engine light went out and runs great so far.
Old 05-14-2009, 10:56 PM
AdderMk2
Banned
AdderMk2's Avatar
glad i could help
AdderMk2 is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: more problems!!
