Figure this one out cause i sure cant!!
Did you follow the instructions at that link?
1. Does coil (+) terminal have voltage IGN ON?
2. Does coil (-) terminal?
3. Does a test light blink when you crank the engine and coil (-) terminal/wire is probed?
4. Have you checked the TFI connector terminals for power at the TFI connector shown at the link?
5. Have you checked the main and EEC grounds.
FYI.... you could disconnect the ECM and there should be spark when you crank the engine. Provide the results from the tests, that way we might be able to help you.
Does coil (+) terminal have voltage IGN ON?--------yes
Does coil (-) terminal----------yes
Does a test light blink when you crank the engine and coil (-) terminal/wire is probed?------------ no
Have you checked the TFI connector terminals for power at the TFI connector shown at the link?---- yes it does
Have you checked the main and EEC grounds--------- yes all good
6. Did you check for spark with the SPOUT plug removed?
7. TFI and PIP sensor checking procedure
LUK
LUK
LUK
LUK
