Water Temp Installation
05-10-2009, 12:13 PM
Inorder to pull ot the swith do i have to unscrew the whole instrument cluster or just the switch? How do you pull out the headlight switch? What kind of wires do I use because the gauge did't come with the wires?
05-10-2009, 12:19 PM
D.R. THE PATHETIC DORK
are you putting in a new headlight switch?? if so there are 4 screws that hold the assembley on, I usually just pull off the bezel/assembley cause often it is brittle due to age and rather risk busting it up trying to pop switch assembly out I just due it as I stated
05-10-2009, 12:20 PM
Just be careful and carefully pry the switch out. You'll probably have to go buy some wire.
05-10-2009, 12:24 PM
I tried looking for the wire in krage and autozone and I couldn't finy any wire. What kind and where did you purchase your wires?
05-10-2009, 12:28 PM
They didn't have any wire? Go to like a stereo shop or something, all auto parts stores should carry wire...
05-10-2009, 12:32 PM
Does it matter what wire i use? What wires do you recommend and which ones did you use?
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
1987,
289,
50,
engine,
ford,
gauge,
gauges,
install,
kragen,
location,
mustang,
sensor,
temp,
water,
wiring
