Want to bypass smog pump... any issues?
Old 05-11-2009, 09:47 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
quit being a puss foot. just remove all your emissions, drop off the pump, get a shorter belt, block off the smog ports on teh back of the head, pinch off your mid pipe tube and remove all the emissions crap (solonoids, vac lines, pump, charcoal canister, remove EGR valve and block it off) i removed all mine about a year ago. no problems with belt or running.
FivePointOhh is offline
Old 05-11-2009, 10:13 AM
302army187
302army187's Avatar
I have to pass emissions....
if we get this house out east ill remove everything. but don't feel like the hassle till then.
302army187 is offline
Old 05-11-2009, 10:22 AM
AdderMk2
Banned
AdderMk2's Avatar
if you are going to remove the belt from the pump, you should either remove the crossover pipe on the back of the heads, or block it somehow. its only 2 bolts and a hose clamp
AdderMk2 is offline
Old 05-11-2009, 10:41 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it may run hot from the water pump turning backwards.
TrimDrip is offline
Old 05-11-2009, 10:46 AM
FivePointOhh
in limbo
**face palm**
they all turn the WP the same way...
Old 05-11-2009, 11:44 AM
AdderMk2
Banned
AdderMk2's Avatar
god your a dumbass
AdderMk2 is offline
Old 05-11-2009, 11:46 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
true
hey does your car stink after removing the charcoal canister?
TrimDrip is offline
Old 05-11-2009, 11:47 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Originally Posted by AdderMk2
god your a dumbass
you know there is a such thing as a reverse rotation pump
TrimDrip is offline
Old 05-11-2009, 11:51 AM
FivePointOhh
in limbo
these are reverse rotation WP's!!!
and no it doesnt stink after you remove your charcoal canister, just move your purge line.
Old 05-11-2009, 11:56 AM
302army187
302army187's Avatar
lol, lot's of WIN in here.
i guess ill just hold off a bit.
i doubt you even gain anything not running it :/
thank's anyway fellas
Quick Reply: Want to bypass smog pump... any issues?
