Wires under hood
Wires under hood
before i paint my engine bay i was going to tuck some wires to make it look cleaner. Can someone tell me which wires i dont need? I have an efi 91 5.0. I already took off the smog, a/c, sway bar but i want to remove all the wires that i do not need. Pictures would help. thanks
dont remove anything, just route them all into the fenders from behind the strut tower. i did it in about 3 hours just the other day. the member ALMOSTSTOCK has the best write up on his website which is linked to his sig. but its pretty self explanitory once you get into it. just need to extend the vacuum lines and maybe 1 or 2 other harnesses.
here is mine, dont mind the destroyed frame rails, if you see my other thread you'll understand. hahah im not done yet with the wire hiding, i still have to move the break lines under the pinch weld and move the BAP sensor. then it will pretty much almost be done beside fixing the frame rails.
You learn quickly, Oh yeah Fixed
jwog666
12-27-2021 08:09 PM
