Well
Old 05-11-2009, 01:41 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
any 5.0 HO motor will work.
all you need to make sure of so it works is that the bell housing is correct for the transmission. 94-95 t5's go with 94-95 bell housings. if they came out of your car together...they are matched and you have no worries.
just know you have one of the weaker t5's so dont abuse the **** out of it. only rate to 265 torque capactity, most 5.0's make more than that stock or really damn close. here is a chart, you'll see your 94 v6 t5 in there
FivePointOhh is offline
Old 05-11-2009, 01:50 PM
SloW 302 StAnG
SloW 302 StAnG's Avatar
Ah i see, 94 v6s did come with t5s right?
Because if they did i can swap it sooner then i thought.
SloW 302 StAnG is offline
Old 05-11-2009, 02:02 PM
FivePointOhh
in limbo
yes sir. you can bolt it right up to a 5.0 without issue.
while its out make sure you swap out for a steel bearing retainer. replace throw out bearing, and when you get your new motor make sure it has a new pilot bearing and rear main seal.
Old 05-11-2009, 02:39 PM
redpony88
redpony88's Avatar
you'll also have a higher o/d as in turning more revs with it, it looks like
redpony88 is offline
Old 05-11-2009, 03:06 PM
AdderMk2
Banned
AdderMk2's Avatar
I have a 8.8 in my basement... with stock SN-95 axles..
come pick it up and give me $100
AdderMk2 is offline
Old 05-12-2009, 08:48 AM
SloW 302 StAnG
Were in RI are you located?
I live in sterling CT right on RI boarder.
I'm very interested...
Old 05-12-2009, 08:50 AM
SloW 302 StAnG
Thanks man you been a HUGE help you have no idea.
Old 05-12-2009, 06:24 PM
AdderMk2
Banned
AdderMk2's Avatar
I live in Smithfield. off Rt44
Its a complete axle minus the brake parts (use your stock stuff)
AdderMk2 is offline
Old 05-12-2009, 07:13 PM
SloW 302 StAnG
So its a hole rearend, every thing is in it besides the brake parts?
how long will you have it for, i could come up with the money pretty soon and pick it up pretty soon also.
Old 05-12-2009, 07:58 PM
AdderMk2
Banned
AdderMk2's Avatar
its not really up for sale, so it isnt going anywhere any time soon
if you want it, get me $100 and come get it
AdderMk2 is offline
