aod guys take a look
I've got a 90lx with aod trans, this is a play car for the street and local 1000ft drag. What is a good rear end gear for these transmissions? I did a search and didnt find many results for the aod's/ Im also planning on a higher stall mabye 2000-2500rpm.
i have 4:10 gears and they make the car feel so much different.
a stall would make the aod a lot better. I would suggest getting a trans cooler and if you want to have more fun with your automatic get a B&M hammer shifter
The AOD suffers from a crappy low gear, so I would go 4.10 if you don't drive it on the freeway. Don't skimp on the converter either, a decent converter will cost you a minimum of $350 for a 2400 - 2600 stall. Stay away from anything cheaper than that. I haven't been happy with any converter or shift kit from B&M, but that's just me. Edge Racing Converters makes a quality product for the AOD http://www.edgeracingconverters.com/...&products_id=1
Im courious since you have the 4:10s what rpm are you taching, at 70mph?
