Nitrous Question?
Nitrous Question?
OK I know a Stock short block wont hold a 200shot for very long before fragging...so my question is this...
will it hold if I put 2 stages (100 shot each) on it one out the gate and one half track at 6* timing, with one step colder plugs and 93 octane?
One way to find out.................. Flip the switch!.......$Boom$.............Let us know how it works out!
My guess it will put a rod thru your block. sooner or later. Then again you might be suprised how long it holds up!
well my only thing is the blocks...well bottom end are good for 450-500...well thats what I read anyhow so i figure if i set the timing down and colder plugs to keep detonation down it should be ok....right?
it's not the horse power, it's the torque.
you might "only" put 400hp to the wheel's, but you will be putting about 500-600ft lb's of torque out.
it's your car.
but im betting it will hold for a bit, blow clutch's, your rear, might tear a motormont. and im betting it will tear that motor apart soon enough.
(plus if your not using a plate or direct injection, your going to have a couple HUGE back fire's through a fogger system)
it's your car.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
