HELP! not firing all 8 cylinders
Old 05-17-2009, 12:13 PM
KG(94/GT)
KG(94/GT)'s Avatar
Post HELP! not firing all 8 cylinders
so i just finished putting the engine back together from a blown head gasket and when i start it the engine shakes a little and isnt firing all 8 cylinders, could it be misplaced spark plug wires or what??
KG(94/GT) is offline
Old 05-17-2009, 12:44 PM
uedlose
uedlose's Avatar
yes. check firing order that could make it shake and misfire in a sense as it is firing but not at the right time. did you put new plugs in it? are all the injectors plugged in? all the wires pushed on tight? how long have you let it run?
uedlose is offline
Old 05-17-2009, 01:01 PM
KG(94/GT)
KG(94/GT)'s Avatar
kept the same plugs, i just went and pushed them all in again. ive let in run for about 2 mins a few times, sometimes it back fires but mostly it shakes back and forth and all the plugs are going into the right spot
Old 05-17-2009, 01:09 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Is your distributor 180 out?
TrimDrip is offline
Old 05-17-2009, 01:18 PM
KG(94/GT)
KG(94/GT)'s Avatar
thats a possibility, ill go try that right now
GimpyHSHS
19
12-19-2023 01:12 PM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: HELP! not firing all 8 cylinders
