Cam question
Old 05-18-2009, 08:31 PM
FORD TOUGH
FORD TOUGH's Avatar
Default Cam question
If I run a ford racing or a trick flow cam will I have to switch to adjustable rocker arms?
FORD TOUGH is offline
Old 05-18-2009, 08:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no but if it were me I'd do away with the waek 5/16 bolt pedastal mount stuff anyday for at least 3/8's stuff and better yet 7/16's
mjr46 is offline
Old 05-18-2009, 08:49 PM
FORD TOUGH
FORD TOUGH's Avatar
I would but I just doing a mild build on a budget and I don't want to spent the money converting to stud mount rocker arms.
Old 05-19-2009, 06:59 AM
Portmaster
Portmaster's Avatar
With a TrickFlow stage one you should be alright. I wouldn't even consider the FRPP cams. Like mjr says you may want to upgrade the weak pedestal mounts if you go any more aggressive that the TF Stage 1
Portmaster is offline
Old 05-19-2009, 12:29 PM
67mustang302
67mustang302's Avatar
Pedestals are fine for street applications. The pedestal itself will prevent side flexion of the capscrew when it's properly torqued, and a high grade 5/16 bolt shaft(like from ARP for instance) will have a huge tensile force that will exceed that of most cam/spring packages you'd be running in a street car. The reason that studs are larger is because they have no pedestal to prevent flexion, so they need extra material for the strength.
The biggest problem with a pedestal setup is that valvetrain adjustments require shims or different pushrods.
67mustang302 is offline
Old 05-19-2009, 02:11 PM
Portmaster
Portmaster's Avatar
I've seen a good many snapped off. If they used ARP bolts it may not be so common. In aluminum heads I see many that have pulled the threads right out of the head. GM had the same problem on the Gen 5 and Gen 6 454 and 502's. They had small 3/8 studs that would snap off when a fairly aggressive cam was used.
Old 05-19-2009, 02:44 PM
67mustang302
Yeah, I wouldn't use them when the cam/spring gets aggressive enough to start pushing the connecting hardware close to it's limits.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Cam question
