fuel pump questions
fuel pump questions
i have a stock fuel pump that is going bad i belive i was woundering if i can use a 255lph pump for now b/c i have a twin turbo kit i want to put on down the road and would the pump work with the stock injectors or would it not be possible let me know thank you
pump would work, but you may need to add an inline pump along with it depending on the kind of setup you're going to be running.
As far as the injectors go, you're going to need to upgrade them one way or another if you're going to do it right
That is unless your going to go the PMU setup; which they all suck.
I have the 55lbs injectors but they are low impadence that i can install but i need to do the ecu i think does any body know of a good ecu to use for the turbo setup if so let me know what yo think of it or do you have any other opions on it thank you for reading
