Stalling after H/C swap
Old 05-21-2009, 06:59 AM
302f150
302f150's Avatar
nooooooo....his light has a dial that you can change to advance the lights timing, and it was set to 10. so when i set it to "10" the first time, it was actually at 20. I went back with another light to check it and it was way off. and yes I pulled the spout connector out
302f150 is offline
Old 05-21-2009, 12:53 PM
87Stallion
87Stallion's Avatar
Not trying to jack the thread but how does the balancer move since it only goes on one way?
87Stallion is offline
Old 05-21-2009, 04:52 PM
302f150
302f150's Avatar
the outer layer and the inner layer are connected pressed together with a rubber insert between them. when they get old its common for them to twist on the rubber, but normally you can see indications of this by some of the rubber bulging out or being cracked and missing. balancer is less than 6 months old. fuel pressure is 37ish at idle, 42 WOT. Still doing it, it'll crank fine one time, then stall the next. come to a stop at a light and it might stall once every 10 times. its a weird problem....
302f150 is offline
Old 05-21-2009, 04:53 PM
302f150
302f150's Avatar
but to make it clear, the timing is now set a 10 degrees with the spout disconnected. It was set at 20ish and it ran horrible....not better.
302f150 is offline
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Stalling after H/C swap
