24lb injectors and speed density
Old 05-24-2009, 07:55 PM
ih8chevy
ih8chevy's Avatar
Default 24lb injectors and speed density
Can I run em? My 86 is running lean with the heads I have on it, Im upgrading to a 70 mm tb/egr spacer and I am porting the gt40 intake to match the heads, and right now the car runs lean and I figure it wont get better with the porting mods. So my question is, how tempermental are 24 lb injectors with speed density?
**Edit** I forgot about the speed density section: Sorry
ih8chevy is offline
Old 05-24-2009, 09:11 PM
AdderMk2
Banned
AdderMk2's Avatar
you are going to injecting 20% more fuel. plan on cranking your fuel pressure down a few pounds. the car is probably going to run like crap for a few days until the ECM settles out the KAM
AdderMk2 is offline
Old 05-24-2009, 09:14 PM
yzfr6i
yzfr6i's Avatar
It will be like running 24lb injectors in a mass air car that still has the 19lb sampling tube in it. Your O2 sensors will try to lean it out, but the computer can only shorten the injector pulse so much. And a WOT the O2s won't have any control and it may be quite fat.
Just a note.. Speed density cars run a bit lean even when stock. That's why stock vs stock a speed density car makes more power than a mass air car. What other mods do you have done to your car? I had an 88GT with quite a few things done and never had a problem running 19lb injectors, and I had the timing set quite hight. I believe 18 deg base.
yzfr6i is offline
Old 05-24-2009, 09:20 PM
Joel5.0
Joel5.0's Avatar
How do you know it's running lean?.... did you run the self tests and got lean code failures from the ECM? You need to ID what's causing the ECM fuel trim to fail.LUK
Joel5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
BeatnikFink
10-01-2015 08:00 PM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 24lb injectors and speed density
