Clutch release cable.
Just adding some information that mine, with 20k on it... is hanging in there, with no problems
I wish I had the money to try the Ford OEM cable to see if it is in fact worth 4 times the price. Or just replace the FRP or Steeda cable when wears.
I do think my long tube headers shorten the life of the cable. You know the bracket of the driver's side frame that holds the cable in place. I installed a second one under the car. Off the crossmember to hold the cable away from my header pipe, closer to the oil pan. It also has a 8" section of heat insulation there too. This bracket/header makes for about a 10 deg angle going into the bellhousing hole. My pressure plate is 2300lbs. That probably doesn't help either.
ya i had my clutch cable go out on me a couple months back it sucks lol so i went to americanmuscle.com and bought the steeda set up with the quadrant and fire wall adjuster it works great i couldnt be happier with it
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
