Gas pouring out of carb
Old 05-25-2009, 04:37 PM
AndrewM6097
AndrewM6097's Avatar
Default Gas pouring out of carb
Just got a carb rebuilt for the 302 on the mustang at napa. Worked nice for a day and now gas is shooting out of the carb. Changed the float, tapped on the bowl and no luck. Is there anything else i should check??
AndrewM6097 is offline
Old 05-25-2009, 05:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
CHECK FLOAT ADJUSTMENT AND THE NEEDLE
mjr46 is offline
Old 05-25-2009, 05:41 PM
AndrewM6097
Honestly i dont know much about carbs... how exactly do i check those things?
Old 05-25-2009, 05:54 PM
Portmaster
Portmaster's Avatar
If it worked OK for a day and now it's shooting out of the carb it probably wont be a float adjustment. It probably has a peice of trash in between the needle and seat/ Has the car been sitting for an extended period of time?
Portmaster is offline
Old 05-25-2009, 06:00 PM
AndrewM6097
Yes the car did sit for a while so i guess that is a possibility.
Old 05-25-2009, 06:23 PM
mjr46
mjr46's Avatar
also what is fuel pressure set at??
mjr46 is offline
Old 05-26-2009, 08:55 AM
AndrewM6097
I'm using a mechanical fuel pump, dont know if that makes a difference or not...
Old 05-26-2009, 12:58 PM
67mustang302
67mustang302's Avatar
You need your fuel pressure to be a max of about 6.5psi at idle.
67mustang302 is offline
Old 05-26-2009, 01:22 PM
AndrewM6097
Do i need a FPR regulator with a mechanical pump? How can i adjust the fuel pressure if need be?
Old 05-26-2009, 01:27 PM
67mustang302
An adjustable FPR. Some pumps are internally regulated to the correct pressure, but it's not always easy to check without a gauge. You need to check yours though. But you said it was fine at first, so either something fubar'd or you got trash in the needle and seat like Portmaster mentioned.
Quick Reply: Gas pouring out of carb
