t5 transmission assembly problem
Old 06-01-2009, 01:18 AM
Tomrob77
Tomrob77's Avatar
Default t5 transmission assembly problem
ok so, there were 2 leaks so i want to replace the seals, 1 was around the shifter, and one was around the rear tail housing, so i removed both and put in new gaskets/sealant. when i went to put on the tail housing it wouldnt go in all the way. I removed the shifter box thingy and it went in all the way, the thing preventing it from closing is a fork looking thing. I was told there was a trick to getting it on, like shifting in a certain order or something, can anyone help me out with this, i can get pictures tomorrow.
Tomrob77 is offline
Old 06-01-2009, 09:39 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
the shift block(block, spring, ball) must got on at the same time as the tailshaft. there is no other way. you just need to mess with it for a while. dont be a pansy man, it isnt easy but they will go together. also to make it easier. ensure you are in nuetral as you are installing, makes the linkage free to move around a little bit making it easier to land it in the designated hole.
if you cant find the hole...just put some hair around it
FivePointOhh is offline
mtgldr
02-03-2024 09:00 PM
04stangman
09-17-2015 01:45 PM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: t5 transmission assembly problem
