Clutch grabs at the very top. Slips high gears.
Old 06-05-2009, 12:36 AM
click
click's Avatar
Originally Posted by 86 5.0L
the cable is pretty loose already did you see the vid?
EDIT: im thinking possibly bent clutch fork, do you ride the clutch pedal alot?
Yea thanks. The cable is already loose and it grabs way to high.
It may be the fork. I'll see if I can notice anything when I look tomorrow. I didn't ride it on this clutch, but on the old one as it was going bad it was having trouble grabbing. So that may have messed up the fork.
click is offline
Old 06-05-2009, 01:43 AM
nacanitihs
nacanitihs's Avatar
the OP said it was changed 10k miles ago so I doubt it
oh sry must have missed that. but if it has been slipping like that for a while it is just ruining the clutch so it still could need replacement anyway.
and OP firewall adjusters are much easier to use. i suggest buying one
nacanitihs is offline
Old 06-05-2009, 04:36 AM
86 5.0L
86 5.0L's Avatar
another thing might have happened was the wrong hook was used, one is for stock cables and one is for adjustable, while the third(on some) is just for getting around a patent and should not be used
86 5.0L is offline
Old 06-05-2009, 02:46 PM
click
click's Avatar
I have the cable hook on the quadrant at the position closest to the firewall so for the most slack.
click is offline
Old 06-05-2009, 04:05 PM
84conversion50
84conversion50's Avatar
it should be on the second.
84conversion50 is offline
Old 06-05-2009, 04:28 PM
click
click's Avatar
Wouldn't that just make the cable tighter and worsen my problem? Unless I'm missing something.
click is offline
Old 06-05-2009, 08:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
dunno???^^^^^^ but there shouldn't be much slack in the cable just a little free play 1/8 inch down on the fork where cable connects
mjr46 is offline
Old 06-06-2009, 04:01 PM
Jfsram
Jfsram's Avatar
84conversion is right. It shouldn't have that much slack in it. 1st hook, second hook it really doesn't matter. Firewall adjuster, quadrant etc. If a clutch is slipping due to improper adjustment. It's too tight. Your's is not too tight so lets move on.
Either the disc is toast, probably. Or the diaphram is broken, maybe. Throwout bearing is seized to the input shaft/sleeve due to lack of lube or a wear groove, but I doubt that one. I say yank it out and have a look.
Jfsram is offline
Old 06-07-2009, 03:33 AM
click
click's Avatar
Thanks for all the replies. I guess it's time to drop the tranny and do work.
click is offline
Thunderball
15
11-22-2015 11:49 PM
TCStangerv6
10-11-2015 05:57 PM
b8checker
10-08-2015 12:55 PM
junior04
09-28-2015 10:53 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Clutch grabs at the very top. Slips high gears.
