Oil Pump/Dizzy Install Problem
Old 06-10-2009, 10:50 AM
Bullitt520
Bullitt520's Avatar
Default Oil Pump/Dizzy Install Problem
I tried searching and tried all the recommended procedues but i still cant get the dizzy to align with the oil pump shaft. I tried bumping the engine over but the shaft is laying against the wall and wont center in the hole. I dont understand how to get it to center in the hole. Ive spent the past 5 months turning this car from an auto 4 cyl to a t5 306 and im so close to finishing the car. Is it possble to take the shaft out or get it centered without dropping the oil pan? If i take the shaft out of the pump and place it in the distributor and drop it all in together would that work? This is killing me guys i need HELP!!!
Bullitt520 is offline
Old 06-10-2009, 10:53 AM
dv3
dv3's Avatar
theres a good video one you tube that explains this but i cant remember the name ...the same company has a whole series of videos on there
dv3 is offline
Old 06-10-2009, 12:26 PM
NotchAbove
NotchAbove's Avatar
Have you tried to put anything down there ? Long Screwdriver ? Socket w/ extension (taped on tightly) ?
NotchAbove is offline
Old 06-10-2009, 03:01 PM
67mustang302
67mustang302's Avatar
Does the shaft have the round clip on it to prevent it from coming out, like it should? It sounds like it's not totally seated correctly in the oil pump.
67mustang302 is offline
Old 06-10-2009, 03:05 PM
mustangsneverdie
mustangsneverdie's Avatar
use a magnet rod and then when you get it in the oil pump completely slide towards the magnet towards the wall so the shaft won't try to come out with it
mustangsneverdie is offline
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
JonnyBlazeGT
11-03-2015 01:10 AM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: Oil Pump/Dizzy Install Problem
