Matching Numbers - Originality question
Old 06-11-2009, 10:32 PM
FoxBodyVert
FoxBodyVert's Avatar
Default Matching Numbers - Originality question
How can you tell if a Fox Body Mustang has the original engine engine/drivetrain? Looking at a 1990 5.0 LX Convertible. Seller represents car as 84k original miles with an engine rebuild by previous owner. No paperwork. Car does run great. I wanna know how to tell if the original motor is still in it and don't know how. Thanks in advance. Chris.
FoxBodyVert is offline
Old 06-11-2009, 10:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
looks and the block if it is painted will often indicate a swap out, other than that it'll hav e a e7 casting on the block = standard
mjr46 is offline
Old 06-12-2009, 12:12 AM
FoxBodyVert
That's part of why I asked. The engine still looks like a neat install. If it was pulled someone did a real good job of putting it back in.
So Ford still doesn't VIN stamp or anything like that? Based on what you told me it wouldf make sense to me I could pull any 5.0 from a Mustang and corectly re install it and noone would ever know. Am i way off here? Does that e a e7 apply to 1990 Mustangs only? What does it decode to? Thanks.
Old 06-12-2009, 12:46 AM
MartyVice
MartyVice's Avatar
I thought all engines, trannys, and rear ends were stamped or had a serial number that should match the car?
MartyVice is offline
Old 06-12-2009, 08:30 AM
stangfreak 347
stangfreak 347's Avatar
in all honesty a motor swap wouldn't effect the value of that model much if any. if it were a 1968 R code mustang then yeah, but an LX convertible is the most sought after mustang out there
stangfreak 347 is offline
Old 06-12-2009, 10:10 AM
ALMOST STOCK
ALMOST STOCK's Avatar
DBL post
ALMOST STOCK is offline
Old 06-12-2009, 10:16 AM
ALMOST STOCK
There are partial Vin numbers (last 8 digits) stamped on the block behind the intake and on the transmission that I know of.
This is my Vin Tag that is riveted to the dash with all the numbers and digits.
And here are the last 8 digits stamped on the block.
Tivo304
08-28-2023 12:19 PM
bjdutch2005
03-24-2017 03:38 AM
Brian Emmer
09-09-2015 02:50 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Matching Numbers - Originality question
