Rear End??
Old 06-13-2009, 10:33 AM
1BIGMOFO
1BIGMOFO's Avatar
Default Rear End??
I ahve a '94 GT
I have 4.10's in it and I just installed a Ford Racing Rear end Girdle on it. The directions say to fill the rear end and to open the stock drain hole and let the excess fluid drain out.
How much fluid should i have put in? Where is the stock drain hole and what do I need to take it out? I found something on the passenger side on the upper side of the casting but i cant see it and dont know what tool I will need to get it out!
Thanks for oyur help,
Rob
1BIGMOFO is offline
Old 06-13-2009, 01:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
stock location of fill is up to the right of the pinion above the casting ridge, you will need a rachet and an extention and that is it
mjr46 is offline
Old 06-13-2009, 01:34 PM
ahittz24
ahittz24's Avatar
3/8 size, it should take about 2 quarts
ahittz24 is offline
Old 06-13-2009, 05:15 PM
1BIGMOFO
1BIGMOFO's Avatar
^^ perfect guys thanks.. My brother was under there and couldnt figure out how to get the plug out for like an hour. I went under there for 2 sec with a mirror and had it all set.
I appreciate the help, thanks.
1BIGMOFO is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Rear End??
