a little help with my 4.10's
Old 06-17-2009, 02:59 PM
Black89LX
Black89LX's Avatar
Default a little help with my 4.10's
so my 4.10 gears and trac lok rebuild kit are supposed to be here tomorrow. any tips, techniques, or suggestions before the install?
also, i was curious as to what my 1/4 mile times will drop to... i ran a 15.6 at 89.5 with my 2.73's
Black89LX is offline
Old 06-17-2009, 08:14 PM
FLcracker9
FLcracker9's Avatar
My tip would be if you've never done one before, take it somewhere to have it done, or have somone experienced help you. If you've done it before, you probably wouldn't be asking this question. The tools required are not your everday tools. At minimum you will need a dial indicator, a dial/digital caliper or micrometer to measure shims, bearing puller(s), a set up pinion bearing (or an old pinion bearing with the center ground out bigger), inch pound torque wrench, a good (strong) impact gun and/or breaker bar with a cheater pipe, and the ability to read the gear pattern after applying marking compound and make appropriate adjustments. Some will say just bolt the ring gear on the diff, and use the same shim that's on the stock pinion, and some get lucky, but that's not the correct way to install them.
FLcracker9 is offline
Old 06-17-2009, 08:43 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I couldn't agree more
PRO50SC is offline
Old 06-17-2009, 09:16 PM
Black89LX
Black89LX's Avatar
well to solve that problem, my girlfriend's dad is helping me out. he owns a trans repair shop and has rebuilt countless rearends.. i was just seeing if there were any tips that people have come across, basically for my own knowledge. but im guessing its pretty straight forward
Old 06-17-2009, 10:35 PM
XPBaller
XPBaller's Avatar
Well thats cool if you have him helping, but, like pro said, that guy up there hit it to a tee. ive rebuilt a few rearends in school, and when i worked for ford.. i wouldnt really consider it "straight foward", because it definitely can be ****ed up if you dont know exactly what youre doing. Plus, like mentioned, you need the proper tools so you can shim it right.
XPBaller is offline
Old 06-17-2009, 11:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no tips needed if an experienced person is doing it
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
junior04
09-28-2015 10:53 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Figure8allday
08-22-2015 11:11 AM
Darrens07GT
08-10-2015 03:59 PM
Quick Reply: a little help with my 4.10's
