Car seems as if it's hitting a rev limiter...
Old 06-22-2009, 09:42 PM
  #21
NoGo95GT
NoGo95GT's Avatar
Another possibility you may have is a bad fuel pump. You can temporarily hook up a fuel gauge to your window and run around block and see if your fuel drops. You can test the pump with a volt meter as well. Or your problem could be a bad FPR. Is your MAF clean? Again, these are all routes that I covered when I had this problem. Luckily all these things can be tested. Also, take out the TFI module and get it re-tested at Autozone just to eliminate that as a possible problem.
NoGo95GT is offline
Old 06-22-2009, 09:46 PM
  #22
pastfast125
pastfast125's Avatar
I tested the fuel pressure a while back when I was having this problem and it was fine.
pastfast125 is offline
Old 06-22-2009, 10:09 PM
  #23
NoGo95GT
NoGo95GT's Avatar
Then I doubt it is a faulty fuel pump or FPR. Again, I'd get the TFI module tested and clean your MAF. Also, disconnect your MAF and see if it runs any better. Again, I am just trying to help you eliminate any problems.
NoGo95GT is offline
Old 06-23-2009, 01:07 PM
  #24
pastfast125
wtf, before I went for a drive I tested the Coolant temp sensor. I only have like 2 volts in, none out. Then when I got back with the car hot, I checked it again. This time I only have .5 volts reference and still nothing out the other side. Wtf is up with that?
I'm gonna get a new DMM in a bit cuz mine is cheap and acting screwy, and I'll check again. I think I'm gonna buy some o2 sensors while I'm there. I'll update in a while.
msavoia23
12
07-07-2018 12:08 PM
FD725
08-23-2015 06:43 AM
MXBT187
08-20-2015 02:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car seems as if it's hitting a rev limiter...
