Oil Pump Drive Shaft
goes in from the bottom, the little metal ring should go towards the dizzy not towards the pump, this way when the dizzy is pulled for any reason the shaft wont pull out of the oil pump and fall down in the pan and ruin your day.
make sure the retainer wont move either. ive had it when i got everything together and tryin to put the dizzy in to be done....the shaft did fall down into the pan, due to the retainer being loose..
Gary Ugarek
63
12-11-2015 02:01 PM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
