Heating Issues on new motor?
Old 06-21-2009, 07:03 PM
smkmup90
smkmup90's Avatar
Default Heating Issues on new motor?
I just finished my 347 stroker motor. It has some trick flow heads,trick flow cam,edelbrock intake,aftermarket fuel pump,42lb injectors,aeromotive fuel rails,high flow water pump,electric fan,cobra 3 core radiator. I fired the car up today and was checking it over before it goes in for the chip and dyno tomorrow, if your driving the car it stays around 180-200 but once you start sitting it has reached 240 I'm not sure if this is a issue I can fix or if the chip will help this issue?
smkmup90 is offline
Old 06-21-2009, 07:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
chip won't help, your clutch fan may not be working, or better yet what are you using to cool it??? stock clutch fan?? or elec cooling fan??
mjr46 is offline
Old 06-21-2009, 08:20 PM
smkmup90
smkmup90's Avatar
It has a flex a lite electric fan.
smkmup90 is offline
mustangsneverdie
mustangsneverdie's Avatar
you might need to get a bigger rad to cool all that new stuff
mustangsneverdie is offline
Old 06-21-2009, 08:25 PM
smkmup90
smkmup90's Avatar
It currently has a 3 core ford racing cobra radiator.
My thought process to the chip helping would be fixing the air/fuel ratio, I'm unsure wheter the car is running lean or not.
smkmup90 is offline
Old 06-21-2009, 08:31 PM
mustangsneverdie
what cfm is your fan
Old 06-21-2009, 08:38 PM
smkmup90
smkmup90's Avatar
3300 cfm....
smkmup90 is offline
Old 06-21-2009, 08:40 PM
mustangsneverdie
what's your timing set at
Old 06-21-2009, 08:44 PM
smkmup90
smkmup90's Avatar
That I dont know, I had someone else set it.
smkmup90 is offline
Old 06-21-2009, 09:03 PM
mustangsneverdie
they could possibly have it set a little too high and how long does it sit before it starts to get hot
Quick Reply: Heating Issues on new motor?
