My hood came up while i was driving
Old 06-23-2009, 03:57 PM
88stang5.0GT
88stang5.0GT's Avatar
Default My hood came up while i was driving
So the metal piece between my hood and widow got crushed beyond repair, does anyone know what that piece is called or where i would be able to get it besides a junk yard?
88stang5.0GT is offline
Old 06-23-2009, 04:57 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the cowl, can be repaired its call body work :P or you can go to the bone yard and pull one.
crack you windsheild and dent your roof too??
rmodel65 is offline
Old 06-23-2009, 05:04 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
I had the same thing happen to me, but it was fixable. You can replace it, but I was told it requires the removal of the fenders, the windshield, etc. so you can drill out all the spot welds.
SonicBlueFiveSlow is offline
Old 06-23-2009, 05:35 PM
86 5.0L
86 5.0L's Avatar
yup, its a structurally important area of the car, much like the roof and rear quarter panels
86 5.0L is offline
Old 06-23-2009, 05:50 PM
FordMustangXBA
FordMustangXBA's Avatar
I had that happen to me twice with my crappy old fiberglass hood. Fortunately, it happened again before I got it fixed from the first time. I found a donor car and cut the cowl out of it, took apart the front clip and welded the new cowl in place of the smashed one. I had to pull a few dents out of the edge of my roof, as well. Needless to say, I went back to a stock hood with the regular latch lol.
FordMustangXBA is offline
Old 06-23-2009, 05:59 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Don't you guys know how to close your hoods?
PRO50SC is offline
Old 06-23-2009, 07:04 PM
SonicBlueFiveSlow
It's not the closing of the hood that's the problem, it's the lack of the hood staying closed.
Old 06-23-2009, 09:21 PM
ALMOST STOCK
ALMOST STOCK's Avatar
And not staying closed is more than likely do to the lack of not checking to see if was closed
ALMOST STOCK is offline
Old 06-23-2009, 10:54 PM
84conversion50
84conversion50's Avatar
cheaper fiberglass hoods can flex to a point where they unlatch
84conversion50 is offline
Old 06-23-2009, 11:08 PM
ALMOST STOCK
I've read a lot of threads about fiberglass hoods mysteriously flying up,(usually do to operator error) but this is the first I've heard of the cheaper fiberglass hoods flexing to the point where they flex they enough to unlatch themselves.
Live and Learn.
Quick Reply: My hood came up while i was driving
