Is this too hot?
#21
Ok, I placed a 2k resistor in the watertemp sensor plug and the low speed fan kicked on immediately. So it looks like my particular issue is with the ECM water temp sensor. Like I stated before it was replaced, not to say it could be a bad one also. I will purchase a new one and try it again. The only thing that I don't understand is that it will kick on the highspeed fan at upper temps, why not at low (unless it skips that range of resistance)? I would check it with a multimeter but it crapped out too. I will pick one up later and see what is going on with the sensor.
Joel5.0 thanks for the info. I will keep ya informed. Thanks ALL.
#22
You have a problem with the grounds....... make sure block to firewall ground strap is OK and contact points are not corroded or paint not allowing a good contact. LUK
#23
Joel5.0,
Need another recommendation from ya. I replace the the temp sensor (ECT) and still no low speed fan????? I checked both the one I replaced and the new one with a multimeter and both running in range compaired to the tech manual. I also checked for bad wire/plug contact. Just wondering if you had any other Ideas with your experience in this area. The 2K resistor fires the low speed fan right up.
#24
Thanks dude ill check it out sometime this week, for now the car is parked cause my radiator was actually leaking, and i have an frpp alumnum radiator, but the stock shroud doenst bolt up to it, so im debating on what to do..i kept the stock shroud cause my e-fan fits perfectly in it.
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
