BBK fuel pressure regulator leaking through vaccum port
Old 06-25-2009, 09:27 PM
5literchevyeater
5literchevyeater's Avatar
Default BBK fuel pressure regulator leaking through vaccum port
I put a BBK fuel pressure regulator on my car last night and turned the pump on (which is switched) to check for leaks and it sprayed out of the vacuum port. I thought that maybe it was just to tight or not set right because I bought it used but I tried adjusting it with no luck. Then I put a cap over the vaccum port and turned the pump on and it shot up to 60 and stayed there untill I backed out the adjusting screw untill fuel leaked out. Is the diaphram inside ripped? Or am I just not doing something right. It seems weird that the fuel pressure is not dropping when I turn the pump off shouldnt it just go down the return line? Any help is apreciated.
5literchevyeater is offline
Old 06-25-2009, 10:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the diaphram is ruptured, replace the regulator
mjr46 is offline
Old 06-25-2009, 10:23 PM
5literchevyeater
I probally bought it like that but what could have caused this to happen. And why did the fuel not go down the return line when I capped the vacuum port.
Old 06-25-2009, 10:59 PM
mjr46
mjr46's Avatar
diaphram is rubber, it dry rots and ruptures, happens over time, get a new one
mjr46 is offline
Old 09-21-2010, 02:02 AM
black91stang
black91stang's Avatar
HI.SAMETHING HAPPENG TO MY 91 STANG , I HAVE A KIRBAN F,P,R. ONY LAST 6 YEARS THIS IS NORMAL LIFE FOR A H, PERFORMANCE F.P.R. WHEN MY 12 YEAR OLD STOCK STILL PUMPING.WHAT DO YOU THING.
EDDIE91STANG75@HOTMAIL.COM
THANK YOU
black91stang is offline
Jb145700
08-21-2022 06:37 AM
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: BBK fuel pressure regulator leaking through vaccum port
