My car has NGK plugs
Old 06-28-2009, 10:20 PM
XPBaller
XPBaller's Avatar
Default My car has NGK plugs
V-power 7s. Should i toss them out and just put autolite platinums in?
also, what are good plug wires to run?
XPBaller is offline
Old 06-29-2009, 06:19 PM
Pony 5.0
Pony 5.0's Avatar
Autolite or Ford copper plugs and frequent changes. I have used Ford Racing wires for years and have not had any problems.
Pony 5.0 is offline
Old 06-29-2009, 08:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
your ride was not designed to be run with platnuims, run a standard copper core resistor plug
mjr46 is offline
Old 06-29-2009, 11:51 PM
XPBaller
XPBaller's Avatar
So 8 or 9mm wires? and autolite copper plugs are the way to go? Why would you say to go those over platinum (not saying youre wrong.. jw). I know a couple people who say to put the platinums in... are they doing something wrong? Also, what should i gap them at, .54?
sorry for all the questions.
thanks guys.
XPBaller is offline
Old 07-01-2009, 12:16 PM
XPBaller
XPBaller's Avatar
BUMP
What do you guys prefer to gap the copper cores to?
And should i go with 8 or 9mm plug wires?
XPBaller is offline
Old 07-01-2009, 06:51 PM
xxxmustangtxhc
xxxmustangtxhc's Avatar
whats wrong with NGKs? i run TR8 s all the time neever had a problem...
xxxmustangtxhc is offline
Old 07-01-2009, 07:08 PM
P.S.I.cho
P.S.I.cho's Avatar
yup i run ngk tr6's on my setup
P.S.I.cho is offline
Old 07-01-2009, 07:26 PM
Joel5.0
Joel5.0's Avatar
thanks guys.
TFI ignition system was not designed to run platinum plugs.... don't get caught by the trend... and I've wasted some $$ testing them, not worth it.... and yes, they are doing something wrong. BTW... NGK spark plugs are quality spark plugs, no need to waste money. Regarding the gap.... start with .045'" .. test it and change to .050".... test again, and see what YOUR setup likes. LUK
Joel5.0 is offline
Old 07-01-2009, 07:34 PM
P.S.I.cho
P.S.I.cho's Avatar
like luk says run a resistor style plug, NGK brand is good but no need to go with plat
Old 07-01-2009, 11:10 PM
XPBaller
XPBaller's Avatar
Well theyre NGK v-power 7s, which are way too hot... right??
I'm just gonna buy some autolite copper cores and gap them at .45 and see what happens
also, like asked before, 8 or 9 mm plug wires? I'm gonna go with ford racing wires... but I dont wanna under/over do it. I have an MSD coil/distributer if that matters..
Thanks for all the feedback, guys
XPBaller is offline
Quick Reply: My car has NGK plugs
