bent core support
Old 06-29-2009, 04:48 PM
Dull_Machete
Dull_Machete's Avatar
Default bent core support
passenger side
driver side
crack on passenger side framerail infront of swaybar
my original plan was to make this my DD/show/auto cross on weekends car. and also there is a couple of holes smashed into the floor pan. it looks like someone tried driving through some woods. should i abandon this POS? can i take a sledge hammer to the bottom of the passenger side core support and straighten it out, and can i just weld the crack in the frame? Or what about the passenger side swaybar mount? it looks like it got smashed and welded crappyly. will this car be able to be straight? please give me your opinionsholding off on renting welder so smooth engine bay and install subframes.
Dull_Machete is offline
Old 06-29-2009, 05:03 PM
mstngsule68
mstngsule68's Avatar
take it to a professional shop and have them fix it.......
mstngsule68 is offline
Old 06-29-2009, 05:10 PM
crusin92red5.0
crusin92red5.0's Avatar
i've seen a lot worse. i think its fixable. take it to a frame shop, so they can make sure its straight, then weld/bang out the bent part and then drive it like you stole it.
crusin92red5.0 is offline
Old 06-29-2009, 05:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have it straightend or weld it up and see if panels will line up
mjr46 is offline
Old 06-29-2009, 10:29 PM
sick89
sick89's Avatar
Yes you can fix it. I wouldnt junk it. You can have it measured out to make sure its straight at a shop. Thats #1 otherwise you will have issues later down the line. Looks like someone has already replaced the core support once before. The crack in the frame can be welded just make sure you add some sort of corrosion protection on the front and backside of the welds. Good luck!!
sick89 is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: bent core support
