rear tires keep rubbing HELP
Old 07-05-2009, 01:36 AM
redgt9200
redgt9200's Avatar
Default rear tires keep rubbing HELP
I HAVE A 92 MUSTANG GT WITH LAKEWOOD LOWER CONTRULE ARMS N HAD MY UPPERS FLIPED N WELD A PIECE IN TO STIFFEN THEM UP. I JUAT PUT 17IN CROBRA R RIMS ON WITH 275/40/R17 TIRES AND THEY RUB ON EVERY BUMP.... I NEED TO KNOW WHAT TO DO TO HELP FIX THIS ASAP THANKS
redgt9200 is offline
Old 07-05-2009, 02:42 AM
mstngsule68
mstngsule68's Avatar
where do they rub?
mstngsule68 is offline
Old 07-05-2009, 07:27 AM
302army187
302army187's Avatar
hopefully your quad shocks are already gone........
normally some light hammering on the inner fender is all it need's. But some have to roll the outer fender too.
gotta find out where it's hitting.
302army187 is offline
Old 07-05-2009, 08:06 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What is the rim width and backspacing
PRO50SC is offline
Old 07-05-2009, 10:50 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
What springs do you have??
projectresto83 is offline
Old 07-05-2009, 11:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I'm with pro50sc on this...we need to know what rim width and back spacing first as well as where are they rubbing??
mjr46 is offline
Old 07-05-2009, 11:31 PM
redgt9200
redgt9200's Avatar
here r the rims i have Style: 1995 Cobra R Finish: Chrome
Size: 17x9 Centercap Size: Large (2-1/2")
Back Spacing: 5.71" (145mm) Offset: +18mm (0.71")
Bolt Pattern: 4x4.25" (4x107.95mm) Fitment: 87-93 LX, GT,
Excludes SVT Cobra it says they would fit i do have large tires on the rear 275/40/17 is that 2 big? should i get something smaller? also the rear looks 2 sit very low ( stock springs) and high iup front?
Old 07-06-2009, 07:28 AM
Tony71502
Tony71502's Avatar
Lower control arms with adjustable spring perches can definitely help. Are lakewood's adjustable? My MM arms fixed my rubbing issue, but then again it was only minimal rubbing even when at the lowest setting. After a slight adjustment the only time it ever rubs is the extreme rare occasion of 4 people in the car when changing a large grade.
Tony71502 is offline
Old 07-06-2009, 10:06 AM
projectresto83
M.A.D. Motorsports
Get a pic of your car on here.
Old 07-06-2009, 02:33 PM
redgt9200
redgt9200's Avatar
here is the fender it rubs on the flat underside of the fender the lakewood lower arms are not adjustable its not letting post the pic so use this like thanks http://i274.photobucket.com/albums/j...400/fender.jpg
Quick Reply: rear tires keep rubbing HELP
