Steering wheel and dash shake @ 65mph +
Old 07-05-2009, 12:30 PM
5pony0
5pony0's Avatar
Default Steering wheel and dash shake @ 65mph +
When I'm driving 65 mph + my steering wheel and dashboard shakes/vibrates. I'm not talking a little bit, it's kinda rough at times.
what are some of the things that could be causing this?
5pony0 is offline
Old 07-05-2009, 12:43 PM
sick89
sick89's Avatar
Get your wheels balanced at your local tire shop and if thats not it have your drive shaft balanced. I would bet its your wheels though.
sick89 is offline
Old 07-05-2009, 05:22 PM
B.Thorson
B.Thorson's Avatar
ya but if you live on like a gravel road like i do if you dont clean the wheel regularly then dust will gather in the wheels and throw your balance off
B.Thorson is offline
Old 07-05-2009, 07:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check tires and rims for run out and balance tires
mjr46 is offline
Old 07-05-2009, 09:05 PM
Jfsram
Jfsram's Avatar
A bad vibration like you describe will need more than a 1 ounce wheel weight to correct.
Check for a bad tire or a bend rim.
Lift the car up and spin the tires. Look at the tread surface for trueness. Or as MJR said, run out. Anything around 40 or 50 thou will be a problem.
Jfsram is offline
Old 07-06-2009, 07:42 AM
Tony71502
Tony71502's Avatar
Don't forget to check your ball joints. Tires being unbalanced from uneven wear(bad alignment) can be the cause 90% of the time. A bad ball joint can cause some wicked steering wheel shake. My steering wheel was jumpin badly at 65+ about 2 years ago, bad enough that two hands and all my strength couldn't stop it. The problem: driver's side ball joint.
Tony71502 is offline
Old 07-06-2009, 12:07 PM
JULIO GEE
JULIO GEE's Avatar
it could also be your harmonic balancer....mine went bad on my 95 gt back in the day...
JULIO GEE is offline
Old 07-06-2009, 12:50 PM
Tony71502
Tony71502's Avatar
If the harmonic balancer had anything to do with it, the vibration would be worse with engine rpm and not vehicle speed. Also I do not think the balancer would transmit that much vibration into the steering wheel.
Old 07-16-2009, 02:28 AM
5pony0
5pony0's Avatar
Great info guys, thanks.
The strange thing is, it doesn't vibrate ALL of the time doing 65+, but I'd say about 75%-90% of the time. I'll have take it to the shop and see what they say...
thanks again
5pony0 is offline
Old 07-16-2009, 09:59 AM
kilby94
kilby94's Avatar
Inspect your driveshaft and u-joints.. My car had a horrible vibration at around 60 when i got it.. It was missing one of the caps on the u-joint.. I guess mine wasn't so much in the steering wheel though.. My whole car shook..
kilby94 is offline
Quick Reply: Steering wheel and dash shake @ 65mph +
