whats your favorite cam?
Old 07-05-2009, 02:13 PM
stockerstang
stockerstang's Avatar
Default whats your favorite cam?
check out my signiture and you'll see my setup.... i am about to have to put on a new water pump, and i figure if i have the water pump off, mind as well throw a cam in... i have a stock setup, but will upgrade top half soon, so what do you recomend as far as cams? what would work well with heads but still give me advantage with the stock heads for now. im interested in input as far as power and sound, but more concerned with power. thanks guys
stockerstang is offline
Old 07-05-2009, 04:23 PM
luckythirteen13
luckythirteen13's Avatar
stock heads, run the stock cam. doesnt matter what you put in there with the stock heads you will see little to no gains. wait till you can get a decent set of heads before doing a cam. if you really want something, go with an ecam. slightly lumpier idle and a few extra hp over the stock cam
luckythirteen13 is offline
Old 07-05-2009, 04:30 PM
w8less
w8less's Avatar
stock cam just add 1.7rr's
w8less is offline
Old 07-05-2009, 07:06 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
My favorite cam is the one that works best for the given combo.
JD1969 is offline
Old 07-05-2009, 07:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
nothing...leave it alone, cam swap = spring swap on heads otherwise your wasting money
mjr46 is offline
Old 07-05-2009, 08:26 PM
XPBaller
XPBaller's Avatar
yeah man... saveup for some gt40s with springs at least before you go dickin with the cam. 1.7rrs would be a nice addition though
XPBaller is offline
Old 07-05-2009, 08:31 PM
smacked1
smacked1's Avatar
mjr46 how many stangs do you own?
smacked1 is offline
Old 07-05-2009, 09:20 PM
Bobert
Bobert's Avatar
Thanks for the info guys im doing a timing cahin rad and water pump i was thinking doing a cam swap too.
No cash for the heads either. And i dont want to take everything apart to swap springs :P
Bobert is offline
Old 07-05-2009, 09:33 PM
mjr46
mjr46's Avatar
currently 3.............the 66 I sold recently and replaced it with an 89 vert project......however ,I'm currently trying to sell my 92 also
mjr46 is offline
Old 07-05-2009, 10:10 PM
stockerstang
right on guys, that makes sense. so just say i had some heads what cam do you like for gt40 heads and a cobra intake?
Quick Reply: whats your favorite cam?
