I COULD USE SOME HELP.......
Old 07-05-2009, 02:29 PM
kyle06786
kyle06786's Avatar
Default I COULD USE SOME HELP.......
SO IM INSTALLING MY EIBACH SPRINGS IN MY 83 CONVERTIBLE WHICH ILL BE RUNNING 90/10 STRUTS FROM COMPETITION ENGINEERING BUT ANY WAY... IM USING THE SPRING COMPRESSORS ( ONE ON EACH SIDE OF THE SPRING ) BUT THE THREADED SHAFT OF THE COMPRESSOR HITS THE TOP OF THE SHOCK TOWER BEFORE THE SPRING CAN BE PUT IN PLACE.... IS THERE A DIFFERENT STYLE OF COMPRESSOR OR A DIFFERENT TECHNIQUE YOU CAN USE ANY HELP APPRECIATED
kyle06786 is offline
Old 07-05-2009, 02:56 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yup, you need the type of compressor that goes thru the center of the spring. Or, if you have a large stiff prybar, you can muscle them in like most ppl do. You gotta be careful though, if the spring pops out look out.
PRO50SC is offline
Old 07-05-2009, 03:20 PM
kyle06786
kyle06786's Avatar
thanks for the quick reply these drag springs are a pain but i did wonder about taking the die grinder and cutting the compressor shafts like 2 or 3 inchs off the end than they would have the clearance i need but wanted to check if any one has tried this
Old 07-05-2009, 09:23 PM
Bobert
Bobert's Avatar
when i first put my eibachs in i didnt need to compress them to put them in, did you get the sport pack? Thats how small they were
To get the old ones out i had the same problem with 2 diff types of compressors so i resorted to chains....
I switched to ford racing springs, which are in there now, and i made my own compressor with two metal plates, two threaded rods, and a few nuts and tools... took for ever but it was worth it...
Bobert is offline
Old 07-07-2009, 01:37 PM
kyle06786
kyle06786's Avatar
im finally gettin them in there just a pain this is my first spring install ive done probably not the easiest ive considered quiting and taking up kniting instead a couple times i would imagine these are easier when theres 2 people or a lift not one guy sitting in a dirt drive way because his garage is full of crap .........
Old 07-07-2009, 01:48 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
sure there is. i do them all the time by myself with this\/\/. right tools make the job easy. ebay 60 dollars later.
i have eibach drag launches and could compeletly install both sides in less than 45 minutes(wheels on and all)
FivePointOhh is offline
Old 07-07-2009, 04:07 PM
5.0kid
5.0kid's Avatar
i suffered through this same thing and let me tell you i will never ever go through that again such a pia. Im so glad i switched to coilovers when i put my k member in because of how long it took to get those things in
5.0kid is offline
Old 07-07-2009, 04:57 PM
tohoopty
tohoopty's Avatar
did you remove the lower strut bolts from the spindle.ive never had to use a spring compressor before to get them in or out.
tohoopty is offline
Old 07-07-2009, 05:25 PM
kyle06786
kyle06786's Avatar
i undid the ball joint tie rod sway bar and the spindle bolts on the strut i spent like 2 hours easy just trying to get every thing perfect , finally did , and i look down and see the rubber bumper for the top of the strut ......... and not relizing that the jack was no longer under the spring........ i took the nut from the top of the strut off and things went flying left and right all that work for nothing...........:i con_doh:
when you reply to this post..... have mercy
Old 07-07-2009, 07:33 PM
Riceinator
Riceinator's Avatar
Stuff like that can be dangerous man, good thing you did not get hurt. And look on the brightside, everything is easier the 2nd time around...and 3rd and 4th.
Riceinator is offline
Quick Reply: I COULD USE SOME HELP.......
