How do i adjust timing?
Old 07-06-2009, 06:34 PM
stangman24
stangman24's Avatar
Default How do i adjust timing?
car runs a bit sluggish, maybe the timing is off. Can someone write some directions for me. thank you
stangman24 is offline
Old 07-06-2009, 06:39 PM
zebo87
zebo87's Avatar
without a light the easiest way is to loosen the nut holding the distributor down(after the car is running). not a whole lot just want to break it loose. then you can rotate the distributor either way but in small incriments. you will be able to hear the difference in the idle. once you have it make sure you tighten the bolt back down. i hope thats what youre looking for.
zebo87 is offline
Old 07-06-2009, 06:44 PM
stangman24
stangman24's Avatar
Thank you. I have been reading that people say 12 deg is a good advancement with running 93 octane. How do i tell if its 12 deg? Is there numbers?
Old 07-06-2009, 07:16 PM
sick89
sick89's Avatar
Yes there will be numbers etched into the balancer. Before you start though you may want to get under the car and clean it up a bit to make sure you can see the numbers good. Alot of times they get dirty and there hard to see.
sick89 is offline
Old 07-06-2009, 07:58 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Do not listen the the above instructions. You need to have a timing light to do this correctly. Adjusting w/o one there is no way to tell where the timing is set.
Read this link!!!
PRO50SC is offline
Old 07-06-2009, 08:05 PM
luckythirteen13
luckythirteen13's Avatar
Read this link!!!
+1, a timing light is manditory when setting your timing. anyone who tells you otherwise is wrong
luckythirteen13 is offline
Pyrate Dave
09-10-2015 07:30 PM
DoctorScary
09-09-2015 07:53 AM
RWHEELS
09-05-2015 03:42 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: How do i adjust timing?
