vacuum?
Old 07-06-2009, 08:59 PM
gavinmosher
gavinmosher's Avatar
Exclamation vacuum?
alright does anyone have a simple diagram for my vacuum lines on my 5.0 my vacuum tree is pretty much just capped off and the vacuum spots under my plenum are capped as well any help or descriptions would be excellent thanks
gavinmosher is offline
Old 07-06-2009, 09:52 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Does this help?
ALMOST STOCK is offline
Old 07-06-2009, 10:12 PM
gavinmosher
would the ones under the plenum cause a high idle? aND ALSO would not having my smog pump hooked up cause any problems with idle because my stang is idling around 2000 rpm
Old 07-07-2009, 12:50 PM
gavinmosher
i need to know what would cause my high idle
Old 07-07-2009, 01:03 PM
86 5.0L
86 5.0L's Avatar
vaccuum leaks, any cracks or missing lines, and which part of your pump is not hooked up? just a belt bypass?
86 5.0L is offline
Old 07-07-2009, 02:08 PM
89Mustangn00b
89Mustangn00b's Avatar
check your set screw on the TB... or the throttle body could just just stuck itself also.
89Mustangn00b is offline
Old 07-07-2009, 03:39 PM
gavinmosher
the whole pump is not hooked to anything theres nothing inside of it anymore it just spins freely because it was locked up and i couldnt afford a pulley replacement
Old 07-07-2009, 11:47 PM
89Mustangn00b
http://www.veryuseful.com/mustang/tech/engine/
Good vacuum lines diagram
Old 07-15-2009, 10:18 AM
86 5.0Lmustang
86 5.0Lmustang's Avatar
Default dual sump oil pan?
any thing i have to change to run a dual sump oil pan? whats the hole on the side of the oil pan for? it has the 2 on the bottom for drains
86 5.0Lmustang is offline
Old 07-15-2009, 12:15 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You can just get rid of it and get a shorter belt. No pulley is needed for the smog pump.
projectresto83 is offline
Quick Reply: vacuum?
