check out my signiture and you'll see my setup.... i am about to have to put on a new water pump, and i figure if i have the water pump off, mind as well throw a cam in... i have a stock setup, but will upgrade top half soon, so what do you recomend as far as cams? what would work well with heads but still give me advantage with the stock heads for now. im interested in input as far as power and sound, but more concerned with power. thanks guys
stock heads, run the stock cam. doesnt matter what you put in there with the stock heads you will see little to no gains. wait till you can get a decent set of heads before doing a cam. if you really want something, go with an ecam. slightly lumpier idle and a few extra hp over the stock cam
