AMMETER NEEDLE IS JUMPING
Old 07-07-2009, 08:58 PM
whitestang86
whitestang86's Avatar
Question AMMETER NEEDLE IS JUMPING
I just noticed today that while sitting at idle and driving down the road the needle on my ammeter is jumping around quickly kind of like a pulsing deal. I do have underdrive pulleys and a stock alternator, still charging at 14.5 but i'm wondering if the regulator is giving me problems and sending goofy readings on my ammeter. Did notice that my back up lights pulsing as well while this is all happening. If anybody had this happen or even a clue is to what to look at i would be thankful. Car starts fine so i don't think it's the battery but i can't rule that out either.
whitestang86 is offline
Old 07-07-2009, 09:11 PM
vt89gtvert
vt89gtvert's Avatar
I would have someone with a multi-meter check out the amps/volts while you are in the car. Make sure you actually have a problem first. Also are you having this trouble at night, while running stereo, heat/AC, or other electrical devices. Could be hard for a stock alt. to keep up with the demand at idle if this is true. When you are driving and higher RPM then your alt will be outputting mroe power.
vt89gtvert is offline
Old 07-07-2009, 09:17 PM
whitestang86
i'm not even running anything and didn't seem to do it as bad while the lights were on, pulsing had slowed down but still was doing it, but yea doesn't seem to do it as bad or at all when i'm runing it a little hard
Old 07-07-2009, 10:18 PM
67mustang302
67mustang302's Avatar
Sounds like a loose connection maybe. Or maybe a loose ground.
67mustang302 is offline
Old 07-08-2009, 07:05 AM
Tony71502
Tony71502's Avatar
Voltmeter not Ammeter >_<
Tony71502 is offline
jwog666
12-27-2021 08:09 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: AMMETER NEEDLE IS JUMPING
