Question about my edelbrock heads
I'm not sure if theyre performers or performer RPMS.
They're ped mount and the numbers "6025" can be found under the valve covers.
I thought the 6025s had 2.02 intake valves, but i measured my intake valve and its a 1.9, but whoever owned the heads last put Ferrea valves in it. Is it possible they downsized the valves for clearance reasons? Is that even possible?
thanks for any help.
Performer RPM Ford
Designed for non-emissions 289, 302, and 351-Windsor Ford engines
Maximum performance in the 1500-6500 rpm range for high performance street
1.90" intake valves are for use with stock pistons and high-flow 2.02" intake valves work with pistons notched for valve clearance
Cylinder Head Specifications
Combustion chamber volume 60cc
Intake runner volume 170cc
Exhaust runner volume 60cc
Intake valve diameter 1.90" & 2.02"
Exhaust valve diameter 1.60"
Valve stem diameter 11/32"
Valve guides Manganese bronze
Deck thickness 5/8"
Valve spring diameter 1.46"
Valve spring maximum lift .575"
Rocker stud 3/8"
Guideplate Hardended steel
Pushrod diameter 5/16"
Valve angle 20°
Exhaust port location Stock
Spark plug fitment 14mm x 3/4 reach, gasket seat
Flow Numbers as tested by Edelbrock's SuperFlo SF-1020 flow bench #60229
Valve Lift .100" .200" .300" .400" .500" .600" .700"
Intake 72 132 183 216 245 249 244
Exhaust 57 104 142 159 170 174 175
Flow Numbers as tested by Edelbrock's SuperFlo SF-1020 flow bench #60259
Intake 70 128 183 219 251 255 246
Exhaust 57 104 142 163 170 174 175
Deck thickness 5/8"
Rocker stud 3/8"
Valve angle 20°
Daddys Girls GTs
09-14-2015 08:46 PM
