car body shifting
car body shifting
the car has been shifting from right to left when i accelerate or decelerate.
whats wrong?
quad shocks have been removed, and southside lower control arms have been installed(previous owner)
at higher speeds it shifts enough to send the car to the right side of the road after i let go of the gas.
thanks
whats wrong?
thanks
If a motor mount is broken, only one side of the motor is restrained so there is a pivot point allowing your driveline to move freely. All that weight moving instantly when the motor is loaded or unloaded creates enough force to shift the car sideways. Been there fixed that.
the arms are bolted and welded...i found the problem, the passengers arm weld was broken and the bolts were loose....other side still attached..although they are some really ****ty welds...gonna cut and redo both sides properly
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
