Sealing an oil pan
Old 07-13-2009, 10:41 PM
hillbilly pony
hillbilly pony's Avatar
Default Sealing an oil pan
Ok so the rear portion of the oil pan is leaking. I really dont want to pull the engine...so can i drain the pan and hit it with brake cleaner and RTV the rear section?? Does anyone have experience with that...
Oh i know it isnt coming from the Rear main i just replaced the Flexplate and i saw it coming from the oil pan.
hillbilly pony is offline
Old 07-13-2009, 11:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
loosen motor mounts, jack motor up and sometimes i LOOSEN K-MEMBER BOLTS TO DROP IT DOWN a tad for extra pan clearance for pick up, and replace gasket
mjr46 is offline
Old 07-13-2009, 11:13 PM
hillbilly pony
That is agood idea...the bitch of it is the gasket is brand new. No passes. it is a one piece gasket to. im wondering if the pan may be a little warped right at the rear main hump.
Old 07-13-2009, 11:53 PM
AdderMk2
Banned
AdderMk2's Avatar
did you use black RTV silicone in the corners of the gasket?
did you use thread sealer on your flywheel bolts?
AdderMk2 is offline
Old 07-14-2009, 01:50 AM
hillbilly pony
Thread sealer yes...i didnt use RTV on the pan cause it was a one piece...figured no seams....
Old 07-14-2009, 08:45 PM
AdderMk2
Banned
AdderMk2's Avatar
you're always supposed to use RTV in the corners... odds are, that is where you are leaking
AdderMk2 is offline
Old 07-14-2009, 09:07 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
wow, deja vu, im having the same problem, and was about to ask about the fix
Would it be a good idea to run a small bead of RTV along the main cap grove and the gasket peice to ensure a good seal, my problem was i didnt put enough highly likely
FuzzyDiceRule is offline
Old 07-14-2009, 09:23 PM
AdderMk2
Banned
AdderMk2's Avatar
no, it is not...
you seal the corners only
AdderMk2 is offline
Old 07-14-2009, 09:44 PM
FuzzyDiceRule
well thats why i asked
Old 07-14-2009, 09:48 PM
87Stallion
87Stallion's Avatar
My does the same ****. I just replaced my gasket with a Ford Racing one piece gasket and it leaks a little from the back. It'll just have to leak, that was a PITA job to drop the pan with the motor in.
87Stallion is offline
bradleyb
11-27-2015 07:50 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: Sealing an oil pan
