Car won't shift into any other gear but 4th. What could be the cause?
Old 07-14-2009, 01:42 AM
MaxEvian
MaxEvian's Avatar
Default Car won't shift into any other gear but 4th. What could be the cause?
I own a 1988 LX with a 302 engine. It was running fine until I decided to punch it. I accelerated it and it took off. I believe I shifted inproperly. Now I can't get it to go into 1st, 2nd or 3rd. What could be wrong? Any possible solutions? IF I do have to replace the trans what would you recommend for LX with a 302 engine?
MaxEvian is offline
Old 07-14-2009, 03:03 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
might have bent a shift fork
rmodel65 is offline
Old 07-14-2009, 08:27 AM
MaxEvian
MaxEvian's Avatar
A shift fork? How difficult is this to repair? Should I start hunting in the junk yards for a new trans?
Max
MaxEvian is offline
Old 07-14-2009, 01:36 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I would look into swapping to a tko just for the future plans.
projectresto83 is offline
Old 07-14-2009, 02:13 PM
67mustang302
67mustang302's Avatar
Possibly a bent shift fork or rail, I think the T5's(if that's what you have) use a single rail system. And yeah, if you plan on making more power later on, you might want to think about an upgrade now.
67mustang302 is offline
Old 07-14-2009, 05:15 PM
94mustang94
94mustang94's Avatar
you might want to go with a tremec 3550 if the funds are too tight for a tko 5 or 6
94mustang94 is offline
Old 07-14-2009, 05:47 PM
mustangsneverdie
mustangsneverdie's Avatar
you'll have to take the trans. apart to fix it
mustangsneverdie is offline
Old 07-14-2009, 07:48 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
isnt this also a symptom of a snapped or damaged input shaft, i had a T5 Rebuild read up that said he ****ed up his input and it only gave him 4th, just a thought
FuzzyDiceRule is offline
Old 07-14-2009, 09:26 PM
AdderMk2
Banned
AdderMk2's Avatar
no, symptom of a broken or stripped cluster gear.
AdderMk2 is offline
Old 07-14-2009, 09:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no cause 4th is part of the input shaft
mjr46 is offline
msavoia23
12
07-07-2018 12:08 PM
antipeterleague
08-18-2015 01:50 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car won't shift into any other gear but 4th. What could be the cause?
