High-idle
Make sure to check your TPS voltage and verify it's correct.
Timing does play a part in ur idle like said above.. 1400rpm idle is alot. So make sure ur timing is good before u set the base idle. You will get better results in the end
To set the base idle I always unhooked the negative cable for a few mins and then unplug the IAC. With the IAC unplugged reconnect the negative cable and start the car. Now u can adjust ur base idle with the idle screw. After u get the car to idle where u want it u can turn the car off and reconnect the IAC. Now ur done. With the IAC reconnected start her back up and take her around the block.
Hope this helps some.
