Smog pump belt size and routing questions.
Hi i took my smog pumo off my msutang today i posted this in another area i think its the wrong spot my bad, but anyway i wanna just over ride the whole pulley scenario and get a short belt and what not. Can anyone tell me what size belt i should get or a rough estimate and how i should route the belt so everything is spinning in the right direction?
if you use a gates ko60695 that will bypass the smog and power steering
you go around the crank opposite like you would normally w/ this belt
that will work if you have UD pullies... otherwise you'll need about 1" longer which would be a ko60705
the numbers indicate what the belt is.... the first 6 = 6 rib belt, the next 0= space, the 695 = 69.5" and so on
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
